Disassembling LG Vortex
  1. Disassembling LG Vortex, Disassembly of LG Vortex: step 1, image 1 of 1
    • Power the phone off
    • The power button is located on top of the phone
  2. Disassembling LG Vortex: step 2, image 1 of 3 Disassembling LG Vortex: step 2, image 2 of 3 Disassembling LG Vortex: step 2, image 3 of 3
    • Find the two thumbnail ridges on the side and top of the phone.
    • One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
  3. Disassembling LG Vortex: step 3, image 1 of 1
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Use the precision screwdriver head #00 to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in the small container to ensure they aren't lost.
  4. Disassembling LG Vortex: step 5, image 1 of 3 Disassembling LG Vortex: step 5, image 2 of 3 Disassembling LG Vortex: step 5, image 3 of 3
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
Jen
22 Reputation
3 Guides authored
Ohio State, Team 1-3, Buehl Spring 2014 Member of Ohio State, Team 1-3, Buehl Spring 2014
OSU-BUEHL-S14S1G3
4 Members
6 Guides authored
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 100
All Time: 4,069
