Disassembling LG VX8550 Front Case
  1. Disassembling LG VX8550 Front Case, Battery: step 1, image 1 of 1
    • Slide the battery release up.
  2. Disassembling LG VX8550 Front Case: step 2, image 1 of 1
    • Remove the battery by lifting away from the case.
  3. Disassembling LG VX8550 Front Case, Case: step 3, image 1 of 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Disassembling LG VX8550 Front Case: step 4, image 1 of 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Disassembling LG VX8550 Front Case: step 5, image 1 of 1
    • Use the iPod opening tool to pry off the back casing.
  6. Disassembling LG VX8550 Front Case: step 6, image 1 of 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. Disassembling LG VX8550 Front Case: step 7, image 1 of 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. Disassembling LG VX8550 Front Case, Motherboard: step 8, image 1 of 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. Disassembling LG VX8550 Front Case: step 9, image 1 of 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. Disassembling LG VX8550 Front Case: step 10, image 1 of 1
    • Remove the motherboard from the front casing by lifting straight up.
  11. Disassembling LG VX8550 Front Case, Keypad Housing: step 11, image 1 of 1
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. Disassembling LG VX8550 Front Case: step 12, image 1 of 1
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. Disassembling LG VX8550 Front Case: step 13, image 1 of 1
    • Lift the keypad housing away from the slider.
  14. Disassembling LG VX8550 Front Case, Front Case: step 14, image 1 of 1
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. Disassembling LG VX8550 Front Case: step 15, image 1 of 1
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. Disassembling LG VX8550 Front Case: step 16, image 1 of 1
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. Disassembling LG VX8550 Front Case: step 17, image 1 of 1
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. Disassembling LG VX8550 Front Case: step 18, image 1 of 1
    • Slide ribbon cable through the slider mechanism.
  19. Disassembling LG VX8550 Front Case: step 19, image 1 of 1
    • Separate the two halves.
Nathan Jones
89 Reputation
10 Guides authored
Cal Poly, Team 34-55, Forte Spring 2010 Member of Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 Members
20 Guides authored
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 2,056
