Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover
  1. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: step 1, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover, Motor Housing Cover: step 1, image 2 of 2
    • Using a spudger, gently pry off the aluminum drip ring.
  2. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 2, image 1 of 1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 3, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 3, image 2 of 2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 4, image 1 of 1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 5, image 1 of 1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 6, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 6, image 2 of 2
    • Using a phillips 2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 7, image 1 of 2 Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 7, image 2 of 2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. Disassembling KitchenAid Classic Mixer K45SSWH Motor Housing Cover: step 8, image 1 of 1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside down to prevent grease from leaking out.
Chris Gonzales
1,519 Reputation
2 Guides authored
Cal Poly, Team 14-28, Maness Fall 2014 Member of Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 Members
22 Guides authored
Past 24 Hours: 31
Past 7 Days: 198
Past 30 Days: 1,148
All Time: 96,884
