Shop the Holiday Gift Guide
Disassembling Keurig Mini B-31 Arm
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
19
All Time:
429
Comments: 10
10 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Disassembling Keurig Mini B-31 Arm, Arm: step 1, image 1 of 1
      • With the needle removed, open the device by pulling up on the handle.
      Ask FixBot
    2. Disassembling Keurig Mini B-31 Arm: step 2, image 1 of 3 Disassembling Keurig Mini B-31 Arm: step 2, image 2 of 3 Disassembling Keurig Mini B-31 Arm: step 2, image 3 of 3
      • Push in on one of the arms attached to the K-cup holder plastic housing to remove it from its rails. The arms are identical for both sides so once one side is free repeat the process for the second side.
      • The plastic is flexible and will not snap with the force applied.
      • Once the arms are removed, the configuration should look like the picture. The K-cup holder housing should be separated from the arms.
      Ask FixBot
    3. Disassembling Keurig Mini B-31 Arm: step 3, image 1 of 1
      • Use a Phillips #1 screw driver to remove the four 12 mm screws that hold the arm assembly in place.
      Ask FixBot
    4. Disassembling Keurig Mini B-31 Arm: step 4, image 1 of 2 Disassembling Keurig Mini B-31 Arm: step 4, image 2 of 2
      • Lift up the arm and pull up the handle assembly. It should easily come off.
      • This white tab falls off easily, remove it and set it aside to ensure it is not lost.
      Ask FixBot
Author
with
Andrew Adriance
1,914 Reputation
7 Guides authored
Cal Poly, Team 17-1, Forte Winter 2014 Member of Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 429
