Disassembling JBL Tour Pro 3 case
Views: 1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
59
Past 30 Days:
279
All Time:
1,024
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
I've disassembled my JBL Tour Pro 3 case due to it acquiring some water damage.
The touchscreen connection ended up breaking but I couldn't get it to work either way.
So for those more experienced with these kind of repairs, here's what the insides look like and how to tear it open with limited damage.
Be careful with the touchscreen!
Tools
    1. Disassembling JBL Tour Pro 3 case, Top ring: step 1, image 1 of 3 Disassembling JBL Tour Pro 3 case, Top ring: step 1, image 2 of 3 Disassembling JBL Tour Pro 3 case, Top ring: step 1, image 3 of 3
      • Start by opening the case and removing the ring at the top by prying it off of the case
      Ask FixBot
    2. Disassembling JBL Tour Pro 3 case, Touchscreen: step 2, image 1 of 1
      • Now that the ring is off, heat up the touchscreen to loosen the adhesive behind it
      • Remove the touchscreen by using a prying pick to get in between the buds crevices and the touchscreen and pry it open just enough to press another pick in between the touchscreen and the case .
      • Use some isopropal alcohol to desolve the adhesive
      Ask FixBot
    3. Disassembling JBL Tour Pro 3 case, insides: step 3, image 1 of 1
      • Pry out the insides by using the prying picks in between the sides
      • Be careful for there is a cable attached to a daughter board which is screwed down at the bottom of the case.
      Ask FixBot
    4. Disassembling JBL Tour Pro 3 case, Daughter board: step 4, image 1 of 2 Disassembling JBL Tour Pro 3 case, Daughter board: step 4, image 2 of 2
      • Remove the 2 +0 size screws and pull out the daughter board
      Ask FixBot
Smokey
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 59
Past 30 Days: 279
All Time: 1,024
