Up to 20% off select tools
Disassembling IINE Retro Pocket Back Plate
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
97
All Time:
373
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the back plate on your IINE Retro Pocket game controller.
    1. Disassembling IINE Retro Pocket Back Plate, Remove the screws: step 1, image 1 of 3 Disassembling IINE Retro Pocket Back Plate, Remove the screws: step 1, image 2 of 3 Disassembling IINE Retro Pocket Back Plate, Remove the screws: step 1, image 3 of 3
      • Set the controller down on your working surface.
      • Flip the controller over so the back of the controller is facing up, with the shoulder buttons facing away from you.
      • Use a Phillips #1 screwdriver to remove the four black 7.5mm screws from the corners of the back plate.
      Ask FixBot
    2. Disassembling IINE Retro Pocket Back Plate, Remove the back plate: step 2, image 1 of 3 Disassembling IINE Retro Pocket Back Plate, Remove the back plate: step 2, image 2 of 3 Disassembling IINE Retro Pocket Back Plate, Remove the back plate: step 2, image 3 of 3
      • Use the tip of an opening pick to separate the back plate. Start at the bottom corner, and pry downwards.
      • As you make your way toward the center, you will eventually disengage the retaining clips located on either side of the status LED array.
      • Be careful not to damage the retaining clips. they're small and thin, and may break easily.
      • Lift the back plate up and away from you, and set it aside.
      Ask FixBot
    3. Disassembling IINE Retro Pocket Back Plate: step 3, image 1 of 1
      • Once the back plate is removed, you now have access to the internals of the controller.
      Ask FixBot
Author
with
Aardimus
318 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 97
All Time: 373
