Introduction
This guide will present easy, step by step instructions on how to remove the front side of the IBM WorkPad c3 case. This case is glued together, so time will need to be spent heating the glue. This time varies, but you should expect to spend at least 10 minutes heating.
Using a hair dryer, slowly heat the edges of the WorkPad.
Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
Using the Plastic Opening Tools, take the front of the case off.
The power button at the top of the device will be loose once the front part of the case is removed.
