Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: step 1, image 1 of 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: step 1, image 2 of 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: step 2, image 1 of 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: step 2, image 2 of 2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: step 3, image 1 of 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive: step 3, image 2 of 2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
Jessica
162 Reputation
7 Guides authored
Cal Poly, Team 4-44, Amido Fall 2010 Member of Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Members
26 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 2,653
