Disassembling HP Photosmart c3180 Top Panel
  1. Disassembling HP Photosmart c3180 Top Panel, Top Panel: step 1, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel, Top Panel: step 1, image 2 of 2
    • Before disassembling your printer, be sure that the printer has been unplugged.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Top Panel: step 2, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel: step 2, image 2 of 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Top Panel: step 3, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel: step 3, image 2 of 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Top Panel: step 4, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel: step 4, image 2 of 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Top Panel: step 5, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel: step 5, image 2 of 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Top Panel: step 6, image 1 of 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Top Panel: step 7, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel: step 7, image 2 of 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. Disassembling HP Photosmart c3180 Top Panel: step 8, image 1 of 2 Disassembling HP Photosmart c3180 Top Panel: step 8, image 2 of 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Top Panel: step 9, image 1 of 1
    • Carefully lift the top panel of the printer away from the printer body.
Jim
1,590 Reputation
10 Guides authored
Cal Poly, Team 20-30, Maness Fall 2011 Member of Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Members
25 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 36
All Time: 6,507
