Disassembling HP Pavilion g7-2275dx Front Panel
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling HP Pavilion g7-2275dx Front Panel, Front Panel: step 1, image 1 of 1
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  2. Disassembling HP Pavilion g7-2275dx Front Panel: step 2, image 1 of 3 Disassembling HP Pavilion g7-2275dx Front Panel: step 2, image 2 of 3 Disassembling HP Pavilion g7-2275dx Front Panel: step 2, image 3 of 3
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
  3. Disassembling HP Pavilion g7-2275dx Front Panel: step 3, image 1 of 2 Disassembling HP Pavilion g7-2275dx Front Panel: step 3, image 2 of 2
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  4. Disassembling HP Pavilion g7-2275dx Front Panel: step 4, image 1 of 1
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  5. Disassembling HP Pavilion g7-2275dx Front Panel: step 5, image 1 of 2 Disassembling HP Pavilion g7-2275dx Front Panel: step 5, image 2 of 2
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
Erik Miller
2,123 Reputation
4 Guides authored
Cal Poly, Team 11-51, Amido Spring 2014 Member of Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Members
21 Guides authored
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 54
