Introduction
There are no prerequisites required for this disassembly, but a spudger or similar opening tool is required to remove the panel.
Parts
No parts required.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  3. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
101 Reputation
9 Guides authored
Clemson, Team 15-3, Benson Spring 2012 Member of Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,012
