Introduction
Use this guide to remove the shell of the handset
Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
Remove the 7.5 mm screw.
Remove the screw cap.
Pull up the phone cord to remove it from the base.
Remove the plastic cover with a Plastic Opening Tool by gently sliding the tool underneath the plastic and pry the cover off.
Remove the paper with a Plastic Opening Tool by gently sliding the tool underneath and prying the paper away from the phone.
Remove the rubber stopper with a Plastic Opening Tool by gently sliding the tool underneath and pry away from the phone.
Remove 3 screws attaching the logic board to shell.
Remove the 13mm screw with a Philips #1 screwdriver.
Remove the 2 13mm screws with washers with a Philips #1 screwdriver.
