Disassembling Galaxy Tab S 10.5 Back Cover
  1. Disassembling Galaxy Tab S 10.5 Back Cover, Disassembling Galaxy Tab S 10.5 Back Cover: step 1, image 1 of 2 Disassembling Galaxy Tab S 10.5 Back Cover, Disassembling Galaxy Tab S 10.5 Back Cover: step 1, image 2 of 2
    • Place the plastic opening tool into the SD card slot or charge port.
    • Try in an upward motion until you see a separation between the tablet and back cover.
  2. Disassembling Galaxy Tab S 10.5 Back Cover: step 2, image 1 of 1
    • Work around the entire device by sliding the plastic opening tool around the rim.
    • If this is the first time, it will be hard to separate the back cover from the tablet.
    • The clips are approximately 5 cm apart. While working around the device, the clips will make a dislocating sound when disconnected.
  3. Disassembling Galaxy Tab S 10.5 Back Cover: step 3, image 1 of 1
    • Remove the back cover once all links have been separated.
    • Be careful when touching any of the internal components of the tablet.
Jordan Soto
3,249 Reputation
6 Guides authored
USF Tampa, Team 3-2, Eyestone Fall 2015 Member of USF Tampa, Team 3-2, Eyestone Fall 2015
USFT-EYESTONE-F15S3G2
3 Members
20 Guides authored
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 138
All Time: 38,273
