Disassembling Energizer WCP310 Base
    1. Disassembling Energizer WCP310 Base, Remove rubber pads: step 1, image 1 of 1
      • Use a spudger to remove the sticky pads that are covering the screws.
      Ask FixBot
    2. Disassembling Energizer WCP310 Base, Remove the four corner screws: step 2, image 1 of 1
      • Under each pad is a screw. You can remove them with a Phillips screwdriver.
      Ask FixBot
    3. Disassembling Energizer WCP310 Base, Remove center screw: step 3, image 1 of 1
      • There is a final screw behind the sticker for the model number. Rather than try to remove the sticker itself, you can just search for a spot where you can push into the sticker with the screwdriver and unscrew it.
      Ask FixBot
    4. Disassembling Energizer WCP310 Base, Open the base: step 4, image 1 of 1
      • Once all five screws are removed, the base separates fairly easily, although using a pick might help.
      Ask FixBot
Gianfranco Berardi
1 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 23
All Time: 23
