Disassembling DualShock 4 Motherboard Assembly
  1. Disassembling DualShock 4 Motherboard Assembly, Controller: step 1, image 1 of 1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
  2. Disassembling DualShock 4 Motherboard Assembly: step 2, image 1 of 3 Disassembling DualShock 4 Motherboard Assembly: step 2, image 2 of 3 Disassembling DualShock 4 Motherboard Assembly: step 2, image 3 of 3
    • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on tool to pry open the casing.
    • Repeat these steps for the right handle.
  3. Disassembling DualShock 4 Motherboard Assembly: step 3, image 1 of 3 Disassembling DualShock 4 Motherboard Assembly: step 3, image 2 of 3 Disassembling DualShock 4 Motherboard Assembly: step 3, image 3 of 3
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
  4. Disassembling DualShock 4 Motherboard Assembly, Disassembling DualShock 4 Motherboard Assembly: step 4, image 1 of 1
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
  5. Disassembling DualShock 4 Motherboard Assembly: step 5, image 1 of 2 Disassembling DualShock 4 Motherboard Assembly: step 5, image 2 of 2
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
  6. Disassembling DualShock 4 Motherboard Assembly: step 6, image 1 of 2 Disassembling DualShock 4 Motherboard Assembly: step 6, image 2 of 2
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
  7. Disassembling DualShock 4 Motherboard Assembly, Disassembly Complete: step 7, image 1 of 3 Disassembling DualShock 4 Motherboard Assembly, Disassembly Complete: step 7, image 2 of 3 Disassembling DualShock 4 Motherboard Assembly, Disassembly Complete: step 7, image 3 of 3
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
Maaz Hussaini
5,831 Reputation
3 Guides authored
Cal Poly, Team 6-21, Maness Winter 2014 Member of Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 Members
40 Guides authored
Past 24 Hours: 105
Past 7 Days: 941
Past 30 Days: 4,251
All Time: 664,647
