Disassembling Dell XPS 16 DA16260 Backplate
    1. Disassembling Dell XPS 16 DA16260 Backplate, Screws: step 1, image 1 of 2 Disassembling Dell XPS 16 DA16260 Backplate, Screws: step 1, image 2 of 2
      • There are 4 T5 Torx screws that need to be removed from the backplate.
      • Once the 4 T5 Torx screws have been removed you need to get a pry tool (preferably plastic to avoid scratches) and pry between the keyboard and the body of the laptop.
      Ask FixBot
    2. Disassembling Dell XPS 16 DA16260 Backplate: step 2, image 1 of 3 Disassembling Dell XPS 16 DA16260 Backplate: step 2, image 2 of 3 Disassembling Dell XPS 16 DA16260 Backplate: step 2, image 3 of 3
      • When you get the keyboard loose do not pull it away aggressively, there is little connector (shown in picture). To remove that connector just pull up on the cable. Once that connector is removed you can move the keyboard out of the way!
      • To re-insert the connector just push down gently but firm, you will hear a small click.
      Ask FixBot
Caleb Martin
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 106
All Time: 234
