Introduction
This guide explains how to remove/replace any part on a Dell Vostro V13 laptop by describing a complete tear-down. Any screwdriver of size PH00 to PH1 will work with the screws on this laptop.
Remove the two plastic dummy cards from the laptop.
Unscrew the six PH00 screws from the bottom of the laptop.
Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
Slide the bottom cover forward and lift it upwards to remove.
Using a plastic opening tool, pry open the top panel containing the power switch. Start with the bottom-right edge closest to the keyboard.
Unclip and remove the ribbon from the panel.
When you're prying this off it might resist a little more than you'd think it should near where it's held by 2 pressure clips near the center.
11 other people completed this guide.
2 Comments
is the CPU removable?
No, it's not. All laptops have soldered ballpoint CPUs and GPUs.
