Disassembling Canon PowerShot SD800 IS Back Cover
  1. Disassembling Canon PowerShot SD800 IS Back Cover, Back Cover: step 1, image 1 of 1
    • Remove one 2.25mm screw on the bottom.
  2. Disassembling Canon PowerShot SD800 IS Back Cover: step 2, image 1 of 1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Disassembling Canon PowerShot SD800 IS Back Cover: step 3, image 1 of 1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Disassembling Canon PowerShot SD800 IS Back Cover: step 4, image 1 of 1
    • Pull off the back cover.
    • The back cover tends to stick in the top left corner due to a metal clip. Jiggle the cover as you side to side pull it out.
Jeremy Rabaino
135 Reputation
6 Guides authored
Cal Poly, Team 20-9, Maness Fall 2010 Member of Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 2,625
