Disassembling Canon EOS Rebel XS Front Cover
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: step 1, image 1 of 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: step 2, image 1 of 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: step 3, image 1 of 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: step 4, image 1 of 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
2 other people completed this guide.
Daniel Bussone
1,251 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
21 Guides authored
2 Comments
This should be labelled: Easy.
tjt263 - Reply
Okay, there are several steps missing.
tjt263 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 5,261
