Shop the Holiday Gift Guide
Disassembling Asus Eee PC 1000HE Lower Assembly
Views: 3.9K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
98
All Time:
3,883
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. Disassembling Asus Eee PC 1000HE Lower Assembly, Lower Assembly: step 1, image 1 of 1
      • Turn off the power and remove the battery before working on your Eee PC
      • Start by removing the keyboard
      • There are four latches on the top of the keyboard, use a paper clip or other object to disengage the latches
      • You may have to pull the keyboard up enough with the object - there is no spring mechanism to pop the keyboard out. One trick is after lifting it enough, to slide it (not too much) upward to remove the bottom side.
      • The keyboard assembly has also two plastic retention points on the sides, and some thermal tape sticking the keyboard down.
      • Caution: the keyboard has a ribbon connector underneath it which must be carefully unplugged before fully removing the keyboard.
      Ask FixBot
    2. Disassembling Asus Eee PC 1000HE Lower Assembly: step 2, image 1 of 2 Disassembling Asus Eee PC 1000HE Lower Assembly: step 2, image 2 of 2
      • 7 screws hold the front plate to the motherboard, as well as the ones on the rear of the PC.
      • Before taking off the case, you need to disconnect the touchpad and hotkeys cables.
      Ask FixBot
adammw
111 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 98
All Time: 3,883
