Disassembling Apple AirPort Extreme Model A1034 Outer Case
  1. Disassembling Apple AirPort Extreme Model A1034 Outer Case, Outer Case: step 1, image 1 of 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 2, image 1 of 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 3, image 1 of 2 Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 3, image 2 of 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Disassembling Apple AirPort Extreme Model A1034 Outer Case: step 4, image 1 of 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
2 other people completed this guide.
Travis Go
158 Reputation
2 Guides authored
Cal Poly, Team 17-15, Regan Fall 2011 Member of Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 17
All Time: 2,777
