Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: step 1, image 1 of 2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: step 1, image 2 of 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: step 2, image 1 of 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: step 2, image 2 of 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: step 2, image 3 of 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: step 3, image 1 of 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
8 other people completed this guide.
Efe Guldogan
860 Reputation
4 Guides authored
USF Tampa, Team 14-23, Meier Fall 2015 Member of USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 44
All Time: 13,633
