Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly
    1. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly, Gamepad disassebly: step 1, image 1 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly, Gamepad disassebly: step 1, image 2 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly, Gamepad disassebly: step 1, image 3 of 3
      • Screws List:
      • 4 x "Torx 6" 7mm screws
      • 6 x "Phillips 1" 10mm screws
      • 10 x "Phillips 1" 5mm screws
      Ask FixBot
    2. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 2, image 1 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 2, image 2 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 2, image 3 of 3
      • 1. Open the back lid
      • 2. Remove battery
      • Remove 4 screws:
      • 2 screws in handles
      • 2 screws under the label
      • 3. Unclip trigger's covers
      • JFYI: My label is not original
      Ask FixBot
    3. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 3, image 1 of 2 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 3, image 2 of 2
      • Using pry tool to split two parts. Start from handles.
      • Open to the right carefully - there is a ribbon cable
      • Slide ribbon cable lock to the right, then unplug ribbon cable
      Ask FixBot
    4. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 4, image 1 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 4, image 2 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 4, image 3 of 3
      • Remove 9 x "Phillips 1" 5mm screws
      • Remove stick caps
      • Eject vibration motors from slots in handles
      • Eject circuit board
      Ask FixBot
    5. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 5, image 1 of 2 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 5, image 2 of 2
      • Remove 6 x "Torx 6" 10mm screws
      • Remove 1 x "Phillips 1" 5mm screw
      • Remove circuitboard with plastic attachments
      Ask FixBot
    6. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 6, image 1 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 6, image 2 of 3 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 6, image 3 of 3
      • Deattach buttons, rubber pads and plastics aligners.
      • While assembling back, make sure, ABXY rubber pad cut angle is on top.
      Ask FixBot
    7. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 7, image 1 of 1
      • Unclip plasctic attachments with buttons and triggers. They are connected by pressure alone to the PCB
      Ask FixBot
    8. Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 8, image 1 of 2 Disassembling 8BitDo SN30 Pro Controller Gamepad disassebly: step 8, image 2 of 2
      • PCB with sticks and vibration motors alone
      Ask FixBot
nett00n
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 33
Past 30 Days: 119
All Time: 498
