Up to 20% off select tools
Disassembling 2011 Chevrolet Traverse Fuse Box
View statistics:
Past 24 Hours:
6
Past 7 Days:
32
Past 30 Days:
136
All Time:
284
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will teach you how to correctly and safely remove the fuse box from a 2011 Chevrolet Traverse.
    1. Disassembling 2011 Chevrolet Traverse Fuse Box, Pull the Release Lever: step 1, image 1 of 1
      • Pull the release lever located under the driver's side dashboard.
      Ask FixBot
    2. Disassembling 2011 Chevrolet Traverse Fuse Box, Open the Hood: step 2, image 1 of 1
      • Walk to the front of the vehicle and pull the safety latch to the side while simultaneously pulling the hood up.
      Ask FixBot
    3. Disassembling 2011 Chevrolet Traverse Fuse Box, Locate the Battery: step 3, image 1 of 1
      • Walk to the back of the passenger side seat.
      • Pull off the trim that is blocking the battery cover.
      • Unscrew the screw holding the battery cover with a T20 Torx bit
      Ask FixBot
    4. Disassembling 2011 Chevrolet Traverse Fuse Box, Unplug the Negative Terminal: step 4, image 1 of 1
      • Remove the Battery Cover
      • Unscrew the Negative Terminal bolt with a 10mm socket
      • Unplug the Negative Terminal
      • !CAUTION! Put something non-conductive between the Negative Wire and the Negative Terminal so that the vehicle doesn't get power
      Ask FixBot
    5. Disassembling 2011 Chevrolet Traverse Fuse Box, Open the Fuse Box and Positive Cover: step 5, image 1 of 1
      • Locate the fuse box at the top left corner of the engine bay
      • Push in the Tabs located around the fuse box
      • Open the positive terminal cap
      Ask FixBot
    6. Disassembling 2011 Chevrolet Traverse Fuse Box, Remove Bolts and Nuts: step 6, image 1 of 1
      • Remove the nut on the positive terminal with a 13mm socket and set the wires aside
      • Remove the bolts holding on the fuse box with a 10mm socket
      Ask FixBot
    7. Disassembling 2011 Chevrolet Traverse Fuse Box, Pull Clips on Fuse Box: step 7, image 1 of 3 Disassembling 2011 Chevrolet Traverse Fuse Box, Pull Clips on Fuse Box: step 7, image 2 of 3 Disassembling 2011 Chevrolet Traverse Fuse Box, Pull Clips on Fuse Box: step 7, image 3 of 3
      • Remove the clips holding on the fuse box
      • This is done easier with a pick
      Ask FixBot
    8. Disassembling 2011 Chevrolet Traverse Fuse Box, Pull Fuse Box Off: step 8, image 1 of 1
      • Pull Fuse Box off and set aside
      • Reassembly is in the reverse order
      Ask FixBot
To reassemble the fuse box, follow these instructions in reverse order.
Author
with
ZeroAutoSkills
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 32
Past 30 Days: 136
All Time: 284
