Disassembling Sony Ericsson W580i Back Cover
  1. Disassembling Sony Ericsson W580i Back Cover, Battery: step 1, image 1 of 3 Disassembling Sony Ericsson W580i Back Cover, Battery: step 1, image 2 of 3 Disassembling Sony Ericsson W580i Back Cover, Battery: step 1, image 3 of 3
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Disassembling Sony Ericsson W580i Back Cover: step 2, image 1 of 1
    • Lift the battery out from the bottom edge.
  3. Disassembling Sony Ericsson W580i Back Cover, Back Cover: step 3, image 1 of 1
    • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
    • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
    • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
  4. Disassembling Sony Ericsson W580i Back Cover: step 4, image 1 of 3 Disassembling Sony Ericsson W580i Back Cover: step 4, image 2 of 3 Disassembling Sony Ericsson W580i Back Cover: step 4, image 3 of 3
    • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
    • Pull the back cover away from the phone.
    • Remove the power button if it has not already come off.
4 other people completed this guide.
Cherie
220 Reputation
2 Guides authored
Cal Poly, Team 5-31, Amido Fall 2011 Member of Cal Poly, Team 5-31, Amido Fall 2011
CPSU-AMIDO-F11S5G31
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 30
All Time: 8,747
