Disassembling Sony Ericsson T68i
  1. Disassembling Sony Ericsson T68i, Disassembling Sony Ericsson T68i: step 1, image 1 of 2 Disassembling Sony Ericsson T68i, Disassembling Sony Ericsson T68i: step 1, image 2 of 2
    • Remove the battery from the back.
  2. Disassembling Sony Ericsson T68i: step 2, image 1 of 3 Disassembling Sony Ericsson T68i: step 2, image 2 of 3 Disassembling Sony Ericsson T68i: step 2, image 3 of 3
    • Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips.
    • When removing the top part do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Disassembling Sony Ericsson T68i: step 3, image 1 of 3 Disassembling Sony Ericsson T68i: step 3, image 2 of 3 Disassembling Sony Ericsson T68i: step 3, image 3 of 3
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. Disassembling Sony Ericsson T68i: step 4, image 1 of 3 Disassembling Sony Ericsson T68i: step 4, image 2 of 3 Disassembling Sony Ericsson T68i: step 4, image 3 of 3
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Disassembling Sony Ericsson T68i: step 5, image 1 of 2 Disassembling Sony Ericsson T68i: step 5, image 2 of 2
    • Pull off the keypad.
  6. Disassembling Sony Ericsson T68i: step 6, image 1 of 3 Disassembling Sony Ericsson T68i: step 6, image 2 of 3 Disassembling Sony Ericsson T68i: step 6, image 3 of 3
    • Gently pull off the infra red window and the vibra motor.
  7. Disassembling Sony Ericsson T68i: step 7, image 1 of 3 Disassembling Sony Ericsson T68i: step 7, image 2 of 3 Disassembling Sony Ericsson T68i: step 7, image 3 of 3
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws holding the cover on.
  8. Disassembling Sony Ericsson T68i: step 8, image 1 of 3 Disassembling Sony Ericsson T68i: step 8, image 2 of 3 Disassembling Sony Ericsson T68i: step 8, image 3 of 3
    • Remove the board and screen.
  9. Disassembling Sony Ericsson T68i: step 9, image 1 of 2 Disassembling Sony Ericsson T68i: step 9, image 2 of 2
    • Lever out the microphone using a small screwdriver or any similar tool.
  10. Disassembling Sony Ericsson T68i: step 10, image 1 of 3 Disassembling Sony Ericsson T68i: step 10, image 2 of 3 Disassembling Sony Ericsson T68i: step 10, image 3 of 3
    • Carefully remove the plastic clips holding the screen on the board.
  11. Disassembling Sony Ericsson T68i: step 11, image 1 of 3 Disassembling Sony Ericsson T68i: step 11, image 2 of 3 Disassembling Sony Ericsson T68i: step 11, image 3 of 3
    • Remove the speaker located in the screen housing just above the screen.
    • Gently pry it out with a small screwdriver or similar tool.
  12. Disassembling Sony Ericsson T68i: step 12, image 1 of 3 Disassembling Sony Ericsson T68i: step 12, image 2 of 3 Disassembling Sony Ericsson T68i: step 12, image 3 of 3
    • Remove the plate from the circuit board protecting the more delicate processing parts.
  13. Disassembling Sony Ericsson T68i: step 13, image 1 of 1
    • Congratulations, you have successfully disassembled your Sony Ericsson T68i!
6 other people completed this guide.
Tim Dascomb
159 Reputation
7 Guides authored
Cal Poly, Team 26-34, Regan Spring 2010 Member of Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 12
All Time: 6,278
