Digital2 D2-912 Speaker Replacement
  1. Digital2 D2-912 Speaker Replacement, External Cover: step 1, image 1 of 1
    • Remove the two Phillips #00 screws from the bottom of the case.
  2. Digital2 D2-912 Speaker Replacement: step 2, image 1 of 2 Digital2 D2-912 Speaker Replacement: step 2, image 2 of 2
    • Wedge the opening tool in the space between the back and the front of the tablet.
    • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
    • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
  3. Digital2 D2-912 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Pull the speaker away from the tablet. It should easily come off, as it is held on with a magnet.
  4. Digital2 D2-912 Speaker Replacement: step 4, image 1 of 1
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Remove the wires from the motherboard using a soldering iron and a solder sucker.
    • Refer to ifixit's soldering guide to remove the solder on the wires.
Lindsay Richardson
394 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Fall 2015 Member of IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 229
