Digital2 D2-912 Motherboard Replacement
    1. Digital2 D2-912 Motherboard Replacement, External Cover: step 1, image 1 of 1
      • Remove the two Phillips #00 screws from the bottom of the case.
      Ask FixBot
    2. Digital2 D2-912 Motherboard Replacement: step 2, image 1 of 2 Digital2 D2-912 Motherboard Replacement: step 2, image 2 of 2
      • Wedge the opening tool in the space between the back and the front of the tablet.
      • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
      • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
      Ask FixBot
    1. Digital2 D2-912 Motherboard Replacement, Motherboard: step 3, image 1 of 1
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Remove the wires shown in the image, using a soldering iron and solder sucker.
      • By removing the wires, you are detaching the battery and speaker from the motherboard.
      Ask FixBot
    2. Digital2 D2-912 Motherboard Replacement: step 4, image 1 of 1
      • Use the Phillips #00 screwdriver to remove the three screws from motherboard.
      Ask FixBot
    3. Digital2 D2-912 Motherboard Replacement: step 5, image 1 of 2 Digital2 D2-912 Motherboard Replacement: step 5, image 2 of 2
      • Detach the capacitive touch controller from the motherboard.
      • Carefully pry the narrow black connector upward to release the ribbon.
      • Remove the ribbon from the connector.
      Ask FixBot
    4. Digital2 D2-912 Motherboard Replacement: step 6, image 1 of 1
      • Locate the camera found in the image.
      • Carefully pry the black connector upward to release ribbon.
      • Remove the black tape to release the camera from the motherboard.
      • Remove and replace the motherboard.
      Ask FixBot
2 other people completed this guide.
Jason Wignot
322 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Fall 2015 Member of IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 97
All Time: 827
