Digital2 D2-912 Camera Module Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
87
All Time:
616
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
We will be replacing the small camera module in the tablet. This may be necessary due to lint/dust buildup in or around the camera lens.
Tools
    1. Digital2 D2-912 Camera Module Replacement, External Cover: step 1, image 1 of 1
      • Remove the two Phillips #00 screws from the bottom of the case.
      Ask FixBot
    2. Digital2 D2-912 Camera Module Replacement: step 2, image 1 of 2 Digital2 D2-912 Camera Module Replacement: step 2, image 2 of 2
      • Wedge the opening tool in the space between the back and the front of the tablet.
      • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
      • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
      Ask FixBot
    1. Digital2 D2-912 Camera Module Replacement, Camera Module: step 3, image 1 of 1
      • Peel the black tape back and pull the black tab back (the tab should come up, not slide).
      • The camera module should then easily come out. Insert your replacement module.
      Ask FixBot
Jason Wignot
322 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Fall 2015 Member of IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 87
All Time: 616
