Digital2 D2-912 Battery Replacement
    1. Digital2 D2-912 Battery Replacement, External Cover: step 1, image 1 of 1
      • Remove the two Phillips #00 screws from the bottom of the case.
      Ask FixBot
    2. Digital2 D2-912 Battery Replacement: step 2, image 1 of 2 Digital2 D2-912 Battery Replacement: step 2, image 2 of 2
      • Wedge the opening tool in the space between the back and the front of the tablet.
      • Carefully work your way around the perimeter, wedging the opening tool between the front and back of the tablet.
      • When the back of the tablet is mostly detached from the front, carefully pull it away completely.
      Ask FixBot
    1. Digital2 D2-912 Battery Replacement, Battery: step 3, image 1 of 2 Digital2 D2-912 Battery Replacement, Battery: step 3, image 2 of 2
      • The battery to be removed is shown with the red box in the photo.
      • Gently remove the battery from the tablet by sliding the metal spudger under the battery.
      • There is glue holding the battery in place, so this step requires some finesse.
      • At this point, your battery should still be attached to the tablet by a red and black wire.
      Ask FixBot
    2. Digital2 D2-912 Battery Replacement: step 4, image 1 of 1
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Take note of which wire goes where (black wire below red wire in photo).
      • In gold writing, 'bat+' indicates the positive terminal (location of red wire), and 'bat-' indicates the negative terminal (location of black wire).
      • To remove the wires from their terminals, use a soldering iron and a solder sucker.
      • Refer to the ifixit solder guide to learn more about how to solder.
      • Attach the black (negative) and red (positive) wires of the new/replacement batteryrespectively to their terminals by soldering them.
      • Position the battery in it's original location, secure with glue.
      Ask FixBot
Lindsay Richardson
394 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Fall 2015 Member of IUPUI, Team 1-1, Harley Fall 2015
IUPUI-HARLEY-F15S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 111
All Time: 1,508
