Introduction
This guide will be showing you how to replace the speaker for the Digital2 D2-861G model. Be sure to carefully remove the speaker to avoid damaging the device.
Now that you have removed the battery, proceed to removing the two 3.51mm screws with your Phillips #00 Screwdriver.
Carefully lift the casing and pull back the tape along with the soldered wire.
Almost done!
