Digital2 D2-861G Battery Replacement
    1. Digital2 D2-861G Battery Replacement, Battery: step 1, image 1 of 1
      • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
      • Place your device on a soft cloth to avoid scratching the screen.
      • Flip your device over so back panel is facing upwards
      Ask FixBot
    2. Digital2 D2-861G Battery Replacement: step 2, image 1 of 2 Digital2 D2-861G Battery Replacement: step 2, image 2 of 2
      • Do not use a lot of force as it can break the clips or the back panel.
      • Insert spudger in the slot below the micro SD card
      • You should hear clips releasing as you pry along the edges.
      • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
      Ask FixBot
    3. Digital2 D2-861G Battery Replacement: step 3, image 1 of 3 Digital2 D2-861G Battery Replacement: step 3, image 2 of 3 Digital2 D2-861G Battery Replacement: step 3, image 3 of 3
      • Look at the images to locate the black tabs.
      • Carefully remove the tape to avoid damaging the device.
      • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
      • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
      Ask FixBot
    4. Digital2 D2-861G Battery Replacement: step 4, image 1 of 2 Digital2 D2-861G Battery Replacement: step 4, image 2 of 2
      • Make sure to not bend or puncture the battery when removing it.
      • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
      • Use prying tools to carefully break the adhesive under the battery
      Ask FixBot
1 Guide Comment
where do you find the replacement battery?
rsdii - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 105
All Time: 1,548
