Digiland DL1168A Rear Case Replacement
  1. Digiland DL1168A Rear Case Replacement, Rear Case: step 1, image 1 of 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Rear Case Replacement: step 2, image 1 of 2 Digiland DL1168A Rear Case Replacement: step 2, image 2 of 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Rear Case Replacement: step 3, image 1 of 2 Digiland DL1168A Rear Case Replacement: step 3, image 2 of 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 210
