Digiland DL1168A Front/Rear Camera Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
48
All Time:
445
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Use this guide to replace the front or rear camera on your Digiland DL1168A tablet. If your device is experiencing issues such as blurry images, failure to open the camera app, or complete camera malfunction, replacing the faulty camera module may resolve the problem. This guide will walk you through the process step-by-step with detailed instructions and photos to ensure a safe and successful repair. Before starting, make sure your tablet is powered off and fully disconnected from any power source to avoid electrical damage or injury.
Tools
    1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: step 1, image 1 of 1
      • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      Ask FixBot
    2. Digiland DL1168A Front/Rear Camera Replacement: step 2, image 1 of 2 Digiland DL1168A Front/Rear Camera Replacement: step 2, image 2 of 2
      • Carefully lift back panel away from the body of the device.
      • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
      Ask FixBot
    3. Digiland DL1168A Front/Rear Camera Replacement: step 3, image 1 of 2 Digiland DL1168A Front/Rear Camera Replacement: step 3, image 2 of 2
      • Desolder the four wires connecting the rear case to the motherboard.
      • Disconnect the wires from the motherboard.
      • Remove the rear case from the device.
      Ask FixBot
    1. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to remove the cover that keeps the camera lens in place.
      Ask FixBot
    2. Digiland DL1168A Front/Rear Camera Replacement: step 5, image 1 of 1
      • Use tweezers to gently begin to lift the back piece off.
      • Lift gently because the lens is connected to the back piece by a small cord.
      Ask FixBot
    3. Digiland DL1168A Front/Rear Camera Replacement: step 6, image 1 of 1
      • After lifting gently both the lens and the back piece will be removed.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 445
