Diagnosis and Repair: Fencing Body Cord
  1. Diagnosis and Repair: Fencing Body Cord, Connect continuity tester: step 1, image 1 of 1
    • First locate the fault location. To do this, connect one wire of the cable to a multimeter (continuity tester) as shown in the picture and bend the cable slightly near a plug.
    • Start bending at the connectors, slowly working your way down the length of the cable. Repeat for each conductor. If a cable break is found, mark the damaged area and the affected wire.
  2. Diagnosis and Repair: Fencing Body Cord, Unscrew plug: step 3, image 1 of 1
    • Unscrew the connector where the fault is.
  3. Diagnosis and Repair: Fencing Body Cord, Mark error location: step 4, image 1 of 1
    • If only one wire has slipped out of the bunched connector, continue with step 10. Otherwise mark wire no. 1 (see photo!) at least 1 cm behind the faulty spot (seen from the plug).
  4. Diagnosis and Repair: Fencing Body Cord, disconnect cable: step 5, image 1 of 1
    • Cut the cable 1 cm before the marking (seen from the plug) with side cutters.
  5. Diagnosis and Repair: Fencing Body Cord, Unscrew plug: step 6, image 1 of 1
    • Remove the bunch plugs from the wires. It may be that the screws are secured with a small amount of varnish, which breaks when unscrewed.
  6. Diagnosis and Repair: Fencing Body Cord, Disconnect the cable: step 7, image 1 of 1
    • Now the cores of the rest of the body cable must be separated from each other. To do this, cut the cable between the wires over a length of 30-35 mm using the cutter knife on the cut-resistant surface.
    • Warning: Make sure you really only cut between the individual wires and don't damage the wires!
    • Caution: the cables usually have a tough silicone jacket, cutting them is a bit difficult!
    • Alternatively - with stronger cables - only 5 mm can be cut at the end between two wires. The wires can then be pulled apart by hand.
  7. Diagnosis and Repair: Fencing Body Cord, Strip the wires: step 8, image 1 of 1
    • Strip the cores over a length of 8 mm. Then twist the bare strands a bit.
    • Warning: stripping is difficult because of the silicone coating, with automatic pliers it may not be possible at all!
  8. Diagnosis and Repair: Fencing Body Cord, Press on Ferrules: step 9, image 1 of 1
    • Use crimping pliers to press the ferrules (1 mm²) onto the strands.
  9. Diagnosis and Repair: Fencing Body Cord, Mount Bunch Plug: step 10, image 1 of 1
    • Screw the bunched plugs back onto the wires. Tighten the screws. Caution: do not use too much force, otherwise the drive of the screws can break out!
    • The screws can be secured against unscrewing under light loads with a small amount of low-strength locking varnish (e.g. LocTite 222).
  10. Diagnosis and Repair: Fencing Body Cord, Mount the cable connector: step 11, image 1 of 3 Diagnosis and Repair: Fencing Body Cord, Mount the cable connector: step 11, image 2 of 3 Diagnosis and Repair: Fencing Body Cord, Mount the cable connector: step 11, image 3 of 3
    • Insert the bunch plugs into one half of the cable plug. Make sure that the marked wire is in position 1 (see photo).
    • The screws in the bunched plugs must point to the side, otherwise the plug cannot be screwed on properly.
    • A bell connector can be used as an alignment aid (see photo).
  11. Diagnosis and Repair: Fencing Body Cord, Screw together the cable connector: step 12, image 1 of 1
    • Screw the cable connector together.
    • Tip: Only then pull off the bell connector.
  12. Diagnosis and Repair: Fencing Body Cord, Functional test: step 13, image 1 of 1
    • Reconnect the multimeter as shown in the photo. Again check all wires for continuity, bending them slightly.
Finish Line
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Torben Schmidt
227 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 213
