Shop the Holiday Gift Guide
Fender Frontman 15r Speaker Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
113
All Time:
9,476
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the speaker is dead or blown, install a new one.
Tools
    1. Fender Frontman 15r Speaker Replacement, Back panel: step 1, image 1 of 1
      • Be sure to unplug the device before proceeding.
      • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
      Ask FixBot
    2. Fender Frontman 15r Speaker Replacement: step 2, image 1 of 1
      • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
      Ask FixBot
    3. Fender Frontman 15r Speaker Replacement: step 3, image 1 of 1
      • Once the top is separated, use your hand to remove the back panel from the unit.
      Ask FixBot
    1. Fender Frontman 15r Speaker Replacement, Speaker: step 4, image 1 of 1
      • Using tape or a post-it, label the input and output wires on the reverb. Remove these wires from the box.
      Ask FixBot
    2. Fender Frontman 15r Speaker Replacement: step 5, image 1 of 1
      • Remove the two female connection terminals from the speaker terminals.
      Ask FixBot
    3. Fender Frontman 15r Speaker Replacement: step 6, image 1 of 1
      • Use a Philips #1 screwdriver to remove the four 21.9 mm Phillips screws from the perimeter of the speaker.
      Ask FixBot
    4. Fender Frontman 15r Speaker Replacement: step 7, image 1 of 2 Fender Frontman 15r Speaker Replacement: step 7, image 2 of 2
      • Gently remove the speaker.
      Ask FixBot
To install the new speaker, follow the instructions given in reverse.
Author
with
Stephen Figueira
157 Reputation
3 Guides authored
Cal Poly, Team 24-30, Regan Fall 2012 Member of Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 113
All Time: 9,476
