Repair Guides
Learn how to fix just about anything with our step-by-step guides.
App
Your pocket repair helper.
FixBot
The friendly AI repair assistant.
Repairability
Learn why fixable products make sense.
Teardowns
Get a sneak peek inside the latest gadgets.
Answers Forum
Share solutions and get help from a friend.
Find Your Community
Find teams, events, and fellow fixers.
Help Out
Help make repair knowledge free and accessible for everyone.
Right to Repair
Learn about the Right to Repair movement and how to be an advocate.
Featured
Quality parts and tools backed by our lifetime guarantee.
Tools
Shop our wide selection of precision tools.
Parts
Shop parts backed by our quality guarantee.
iPhone Batteries
Batteries tested and guaranteed plus a kit with everything you need.
Unscrew the 6 Torx T5 screws from the back of the device
Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
Screen Information: Model AM0310R-04 Lot # NHT18080052
Using a spudger, unplug the Charging Port connector from the motherboard.
Remove the 2 silver Torx T5 screws holding the charging port down.
Remove the Charging Port Assembly from the motherboard.
Remove the silver Torx T5 screw holding the motherboard down.
Using a spudger, carefully remove the battery connector on the left side of the motherboard.
Using a spudger, carefully pry up the motherboard to remove it.
Using a spudger, carefully pry up and remove the speaker at the top.
Remove any remaining adhesive.
Put down new adhesive tape(be careful not to let it get in the way of the speaker).
Stick the new speaker down.
with 1 other contributor
15,595 Reputation
8 Guides authored
Badges: 36
+33 more badges
Choose a size and copy the code below to embed this guide as a small widget on your site / forum.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 340
