Introduction
This guide shows how to disassemble the IBM ThinkPad i Series 1200. In addition, it explains how to remove the microprocessor to change its thermal paste.
Before beginning, ensure the notebook is powered off.
To remove it, slide the two switches in such a way that it is unlocked, as shown in the picture, and then remove it.
Remove the screw in the lower corner.
Remove the "cover" of the disk.
Pull the "hook" that is attached to the disc to remove it.
Remove the indicated screw from the backside of the notebook.
Take off the cover that protects the RAM memory.
Remove the two indicated screws.
Remove the metal protector that is found above the plate.
Remove the indicated screws from the backside of the PC.
Remove the optical drive by simply sliding it out.
First, remove the plastic components indicated.
Remove the two screws that are found after step one.
Remove the plastic protector that is found on the upper part.
Remove the plastic frame that surround the netbook.
Remove the metallic protector.
Put aside the CPU cooler.
Once step 13 is completed.
Remove the plastic covers that surround the display.
Remove the indicated screws that hold the metallic covering.
Underneath you will find the inverter.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
