Tektronix TBS1062 Oscilloscope Disassembly
  1. Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: step 1, image 1 of 3 Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: step 1, image 2 of 3 Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: step 1, image 3 of 3
    • Remove all eight plastic buttons.
    • Remove the five Torx T15 screws.
    • Remove the front panel by pulling it off
  2. Tektronix TBS1062 Oscilloscope Disassembly, Removing the back cover: step 2, image 1 of 2 Tektronix TBS1062 Oscilloscope Disassembly, Removing the back cover: step 2, image 2 of 2
    • Remove the power plug from the cover
    • Firmly grasp the ON/OFF switch and pull it straight out of the box.
    • Press the button into the ON/OFF button recess until it clicks into place.
    • Remove the two black plastic plugs from the bottom.
    • Remove the back cover.
  3. Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: step 3, image 1 of 3 Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: step 3, image 2 of 3 Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: step 3, image 3 of 3
    • Even when disconnected, the power supply can retain a dangerously high voltage. Avoid contact with the rear of the board or other components. Use insulated electrician's gloves. Ensure that the capacitors are discharged before touching them.
    • Disconnect the J101 power supply connector from the motherboard.
    • Disconnect the earth connection.
    • Remove the 5x Torx T15 screws.
    • Remove the power supply board.
  4. Tektronix TBS1062 Oscilloscope Disassembly, Control panel removal: step 4, image 1 of 2 Tektronix TBS1062 Oscilloscope Disassembly, Control panel removal: step 4, image 2 of 2
    • Disconnect the black cable from the motherboard
    • Pull the control board plate
  5. Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: step 5, image 1 of 3 Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: step 5, image 2 of 3 Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: step 5, image 3 of 3
    • Loosen the three nuts holding the signal connectors.
    • Loosen the three T15 Torx screws.
    • Remove the cables.
    • Remove the main board.
  6. Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: step 6, image 1 of 3 Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: step 6, image 2 of 3 Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: step 6, image 3 of 3
    • Disconnect the ribbon cable and the LCD backlight cable from the motherboard.
    • Loosen the 4x 8mm nuts from the display supports.
    • Remove the LCD display.
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Jose Gustavo Abreu Murta
4,598 Reputation
9 Guides authored
2 Comments
This guide is written in English, not Portugese. How can that be changed?
Christopher Sean Harris - Reply
Hi Christofer.
Do you intend to translate into Portuguese? I messed up the language when editing it.
Jose Gustavo Abreu Murta - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 395
