Desktop PC Left Panel Replacement
Views: 10K
View statistics:
Past 24 Hours:
8
Past 7 Days:
38
Past 30 Days:
240
All Time:
10,335
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Removing the left panel of a desktop computer is an important skill to have for repair and troubleshooting purposes. The left panel must be removed before any repairs can be performed on the inside of the computer. In addition, computers with heating problems could benefit from having the left panel removed.
Tools
    1. Desktop PC Left Panel Replacement, Left Panel: step 1, image 1 of 1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
      • These screws can usually be removed by hand.
      • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
      Ask FixBot
    2. Desktop PC Left Panel Replacement: step 2, image 1 of 2 Desktop PC Left Panel Replacement: step 2, image 2 of 2
      • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
      • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
      Ask FixBot
24 other people completed this guide.
David Lennon
10,207 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
132 Guides authored
3 Guide Comments
What is the name of the case used in this tutorial?
Nicolas Hunter - Reply Share
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - Reply Share
I have this same case in black and want to know what model it is.
numanair - Reply Share
Past 24 Hours: 8
Past 7 Days: 38
Past 30 Days: 240
All Time: 10,335
