How to Fix a Delta 5-Function Showerhead Model 75554
  1. How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: step 1, image 1 of 3 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: step 1, image 2 of 3 How to Fix a Delta 5-Function Showerhead Model 75554, How to Fix a Delta 5-Function Showerhead Model 75554: step 1, image 3 of 3
    • Unscrew the head of the shower from the pipe with a pipe wrench.
    • While using the pipe wrench, make sure not to clamp it too tight because it will crack the plastic.
  2. How to Fix a Delta 5-Function Showerhead Model 75554: step 2, image 1 of 2 How to Fix a Delta 5-Function Showerhead Model 75554: step 2, image 2 of 2
    • Fill a large bowl with equal parts hot water and white distilled vinegar to get rid of hard water build up.
  3. How to Fix a Delta 5-Function Showerhead Model 75554: step 3, image 1 of 2 How to Fix a Delta 5-Function Showerhead Model 75554: step 3, image 2 of 2
    • With the tip of a pocketknife, pick out the rubber, black washer in the attachment.
    • Using your fingertips press a new 1" black rubber washer into the head attachment. The new washer will allow water to flow correctly with more pressure.
    • Pocketknives can be very very sharp!
  4. How to Fix a Delta 5-Function Showerhead Model 75554: step 4, image 1 of 2 How to Fix a Delta 5-Function Showerhead Model 75554: step 4, image 2 of 2
    • Wipe down with shower pipe with a hot water and vinegar soaked scrub brush.
  5. How to Fix a Delta 5-Function Showerhead Model 75554: step 5, image 1 of 2 How to Fix a Delta 5-Function Showerhead Model 75554: step 5, image 2 of 2
    • Wrap Teflon tape around the legs of the spout about 3 times to ensure that it will screw on tight when the head is put back on.
    • Now is the time to take the shower head out of the vinegar water.
  6. How to Fix a Delta 5-Function Showerhead Model 75554: step 6, image 1 of 3 How to Fix a Delta 5-Function Showerhead Model 75554: step 6, image 2 of 3 How to Fix a Delta 5-Function Showerhead Model 75554: step 6, image 3 of 3
    • Twist the shower head back onto the pipe and tighten it with the pipe wrench.
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 1,516
