Dell XPS M1710 Memory Replacement
      • NOTE: In order to take advantage of the dual channel bandwidth capability, both memory slots must be populated and must match in size
      • Memory modules purchased from Dell are covered under your computer warranty.
      • CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the Product Information Guide.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • NOTICE: To avoid damaging the system board, you must remove the battery before you begin working inside the computer.
      • Ground yourself by touching one of the metal connectors on the back of the computer
      • Turn the computer over, loosen the captive screws on the memory module cover, and then remove the cover.
      Ask FixBot
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips
      • If you are replacing a memory module, remove the existing module:
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector
      Ask FixBot
      • NOTE: If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
      • Ground yourself and install the new memory module:
      • Align the notch in the module edge connector with the tab in the connector slot
      • Slide the module firmly into the slot at a 45-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
      Ask FixBot
      • NOTICE: If the cover is difficult to close, remove the module and reinstall it. Forcing the cover to close may damage your computer
      • Replace the memory module cover.
      • Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
      • Turn on the computer.
      • As the computer boots, it detects the additional memory and automatically updates the system configuration information. If prompted, press <F1> to continue.
      • To confirm the amount of memory installed in the computer, click the Start button, click Help and Support, and then click Computer Information.
      Ask FixBot
Amia Frazier
887 Reputation
7 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,277 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 59
All Time: 359
