Dell XPS M140 Hard Drive Disk (HDD) Replacement
  1. Dell XPS M140 Hard Drive Disk (HDD) Replacement, Battery: step 1, image 1 of 1
    • The first step is to turn over the laptop
  2. Dell XPS M140 Hard Drive Disk (HDD) Replacement: step 2, image 1 of 1
    • Locate the slide lock for the battery.
  3. Dell XPS M140 Hard Drive Disk (HDD) Replacement: step 3, image 1 of 2 Dell XPS M140 Hard Drive Disk (HDD) Replacement: step 3, image 2 of 2
    • Slide the lock and pull out the battery.
  4. Dell XPS M140 Hard Drive Disk (HDD) Replacement, Hard Disk Drive (HDD): step 4, image 1 of 2 Dell XPS M140 Hard Drive Disk (HDD) Replacement, Hard Disk Drive (HDD): step 4, image 2 of 2
    • loosen the two screws that secure the hard drive cover.
    • The screws won’t come out fully. Once you feel like the door is loose enough, it should come right off.
  5. Dell XPS M140 Hard Drive Disk (HDD) Replacement: step 5, image 1 of 1
    • Remove the old HDD from the casing. This is done by simply sliding it out.
Travis Morazzini
207 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 7
Past 30 Days: 13
All Time: 1,071
