Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement
  1. Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement, Wi-Fi Chip: step 1, image 1 of 2 Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement, Wi-Fi Chip: step 1, image 2 of 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place
  2. Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement: step 2, image 1 of 2 Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement: step 2, image 2 of 2
    • Insert the flat edge of the opening tool in between the back casing to remove the back casing.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement: step 3, image 1 of 2 Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement: step 3, image 2 of 2
    • Use a JIS #0 Screwdriver to remove the one 3.0 mm screw.
  4. Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement: step 4, image 1 of 2 Asus VivoBook Q302LA-BHI3T09 Wi-Fi Chip Replacement: step 4, image 2 of 2
    • Disconnect the black and white wires that provide power and data transfer to the Wi-Fi chip.
Deric Wright
639 Reputation
3 Guides authored
USF Tampa, Team S5-G5, Eyestone Spring 2018 Member of USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 416
