Introduction
The cooling fans help keep the laptop from over heating. If your laptop seems especially hot or loud, it could be caused by a faulty fan or two.
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
Using the Small Plastic Spudger, carefully disconnect the white connector from the black port.
Using the Phillips #00 Screwdriver, remove the two 4 mm long screws.
The left fan screw locations are circled in red.
The right fan screw locations are circled in orange.
