Dell XPS 15 9550 Cooling Fan(s) Replacement
  1. Dell XPS 15 9550 Cooling Fan(s) Replacement, Back/Underside Panel: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Cooling Fan(s) Replacement: step 2, image 1 of 2 Dell XPS 15 9550 Cooling Fan(s) Replacement: step 2, image 2 of 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Cooling Fan(s) Replacement: step 3, image 1 of 3 Dell XPS 15 9550 Cooling Fan(s) Replacement: step 3, image 2 of 3 Dell XPS 15 9550 Cooling Fan(s) Replacement: step 3, image 3 of 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Cooling Fan(s) Replacement, Cooling Fan(s): step 4, image 1 of 1
    • Using the Small Plastic Spudger, carefully disconnect the white connector from the black port.
  5. Dell XPS 15 9550 Cooling Fan(s) Replacement: step 5, image 1 of 3 Dell XPS 15 9550 Cooling Fan(s) Replacement: step 5, image 2 of 3 Dell XPS 15 9550 Cooling Fan(s) Replacement: step 5, image 3 of 3
    • Using the Phillips #00 Screwdriver, remove the 2 4 mm long screws.
    • The location of the 2 screws is different on each fan.
    • The left fan screw locations are circled in red.
    • The right fan screw locations are circled in orange.
Brandon Schmidt
2,090 Reputation
3 Guides authored
UW Stout, Team S6-G1, Ogden Fall 2018 Member of UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Members
23 Guides authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 62
All Time: 12,098
