Introduction
If your Dell XPS 15 9550 laptop will not power on without being plugged in or not hold a charge for an extended period of time, you may need to replace your battery.
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
Use a Philips #00 Screwdriver to remove the seven 3 mm long screws from the perimeter of the battery.
Firmly grasp the black connector on both sides.
Carefully pull the connector towards the battery, to release the connector and the battery from the laptop.
