Dell XPS 15 9550 Battery Replacement
  1. Dell XPS 15 9550 Battery Replacement, Back/Underside Panel: step 1, image 1 of 1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Battery Replacement: step 2, image 1 of 2 Dell XPS 15 9550 Battery Replacement: step 2, image 2 of 2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Battery Replacement: step 3, image 1 of 3 Dell XPS 15 9550 Battery Replacement: step 3, image 2 of 3 Dell XPS 15 9550 Battery Replacement: step 3, image 3 of 3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Battery Replacement, Battery: step 4, image 1 of 2 Dell XPS 15 9550 Battery Replacement, Battery: step 4, image 2 of 2
    • Using a Philips #00 Screwdriver, remove the seven 3 mm long screws from the perimeter of the battery.
    • Each screw is labeled "M2X4" with an arrow pointing to the screw.
  5. Dell XPS 15 9550 Battery Replacement: step 5, image 1 of 1
    • Gently lift up on the backside of the battery.
  6. Dell XPS 15 9550 Battery Replacement: step 6, image 1 of 3 Dell XPS 15 9550 Battery Replacement: step 6, image 2 of 3 Dell XPS 15 9550 Battery Replacement: step 6, image 3 of 3
    • Firmly grasp the black connector on both sides.
    • Carefully pull the connector towards the battery, releasing the connector and the battery from the laptop.
Brandon Schmidt
2,090 Reputation
3 Guides authored
UW Stout, Team S6-G1, Ogden Fall 2018 Member of UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Members
23 Guides authored
Past 24 Hours: 13
Past 7 Days: 108
Past 30 Days: 602
All Time: 73,876
