Introduction
Before the majority of components can be accessed to be replaced, the back panel will need to come off.
Turn the laptop upside down.
Using a T5 Torx Screwdriver, remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use the Phillips #00 Screwdriver to remove the two 10 mm long screws.
Carefully lift the 2 corners of the back panel close to the hinge upwards, releasing the whole panel.
