Introduction
The large plastic palm rest may need replacement if damaged or discolored. Removal of the palm rest is also required to reach further into the laptop's internal components.
Locate the spring latch on the bottom of the device that will unlatch the battery.
Hold the spring latch in the open position and pull the battery out of its recess.
Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
Pull the panel upwards and towards the battery to remove.
Put the panel to the side, exposing the RAM.
The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
Detach the plastic cosmetic cover from the hard drive.
Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
Remove two 4.5mm screws with JIS 1 screwdriver marked by the letter "K" in the optical drive bay.
Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K"in the hard drive bay.
Open the display to provide room for the palm rest to come out.
In the hard drive bay, push the "push" pad to lift up the palm rest.
Disconnect the status bar cable by pulling the pin connector upward.
Finish lifting up the palm rest.
